Mercedes Econic NGD Euro VI
Pojazdy dostawcze, ciężarowe i specjalistyczne zasilane CNG
W Hanowerze na IAA 2014 Mercedes zaprezentuje Econica na CNG z normą spalin EURO VI. W samochodzie będzie mocniejszy silnik - 7.7 l o pojemności 301 KM (221 kW). Dzięki zbiornikom kompozytowym masa instalacji CNG będzie ważyć tylko 500 kg.
Innovative M 936 G natural gas engine in the Econic
The new M 936 G natural gas engine in the Econic is based on the OM 936 turbodiesel engine from the new 7.7 l BlueEfficiency Power generation. As a mono-fuel engine, it runs on compressed natural gas (CNG) and has an output of 221 kW (301 hp) while delivering maximum torque of 1200 Nm. Figures like these, in combination with its impressive power delivery, place the single-stage turbocharged engine on a par with its diesel-powered counterpart. At the same time, it sets new standards in terms of environmental compatibility, with CO2 emissions up to 22 percent below those of a diesel engine. Using biogas further improves the carbon footprint.
Virtually soot-free combustion obviates the need for a particulate filter of the kind now customary in diesel engines with the introduction of the Euro VI standard. Exhaust gas aftertreatment is by means of a three-way catalytic converter. And another advantage: The natural gas engine has an even lower noise level than the already quiet OM 936 diesel engine. The additional weight compared to diesel drive has been halved to only around 500 kg. This is by virtue of gas cylinders with thin steel walls and a carbon-fibre mantle.
Źródło: http://media.daimler.com/dcmedia/0-921- ... 7514209817
Wróć do „Pojazdy ciężarowe i dostawcze powyżej 3,5 t”
